Comp polymer valve cover questions...
Old Jun 11, 2001 | 12:32 PM
Biochem's Avatar
Car: 2002 SOM z28
Are they noisey? Will they clear a stud girdle? Will an open air element, EGR valve, alt bracket, etc. clear them? Color preference?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jun 11, 2001 | 10:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pretty aren't they. I never bought a set because there are no holes for my crankcase breathers. I'm sure you just need to cut the holes required.
Try asking CompCams those questions.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 481.6
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jun 12, 2001 | 01:12 AM
Basett_Racing's Avatar
They are not noisy, maybe even a little quieter than stock because they are so thick. They will clear stud girdles, or at least they did the Comp girdles on my brothers truck. To add holes, thats easy too. They have pre-shaped places underneath to locate a 1 1/4" hole saw (the instructions actually TELL you to do it this way) for making holes. Comp also sells some trick polymer breather stands for them also. Our experience with them has been good. We got the red ones. They have little points or "teeth" on the sealing rail to hold the gasket in place. They look really good, and seal very well also.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.63 @ 113.25, w/ a 7.39 1/8 @ 93.04, and a 1.626 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Old Jun 12, 2001 | 06:55 AM
Biochem's Avatar
Car: 2002 SOM z28
Thanks guys! I all ready knew about having to drill the hole for the breather. I think I am leaning towards the blue ones!
Old Jun 12, 2001 | 08:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Hey Ray, doesnt this belong in General Tech?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
