starting problem
Old Jun 12, 2001 | 08:30 PM
Javi's Avatar
starting problem
My problem is that when i start my car, it doesn't start the firt time. It starts the second time that i turn the key, but it blows smoke that smells like gasoline. my car is an 88 GTA. What do you guys think is the problem?
Old Jun 12, 2001 | 09:07 PM
Vader's Avatar
Javi,
Welcome aboard!
Without further data, any advice is purely speculative, but your description sounds like a possible leak in one or more injectors. This floods the engine when it is turned off, and usually requires some cranking to clear the chambers to allow ignition. The strong odor of unburned fuel is another indication. If you have a fuel pressure gauge, you can monitor the fuel rail pressure when the engine is turned off and determine if any of the injectors are leaking.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
