will 350 head on my 305
Old Dec 19, 2004 | 09:30 PM
thomas_iroc's Avatar
will 350 head on my 305 give me more hp?I have a 86 carb z28.
Old Dec 19, 2004 | 09:33 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
no it will lower the compression ratio. 305 on a 350 will help a lot but not the other way around.
Old Dec 19, 2004 | 09:41 PM
ljnowell's Avatar
You will lose some compression if you go that way. Some people will do it, and claim that if the heads are good enough, the increased flow will make up for it. I'm not sure I agree with that though. If they are 64cc heads, with 1.94 1.50 or 1.60, they may be worth it, if they have been ported for flow. Personally, I would rather re-work the 305 heads. Remember though, if you put bigger valves in your 305 heads, you will be increasing the chamber size also, therefore losing compression. Its kind of a catch22. The only real way to get ahead is to drop the 305 and get a 350, but this isnt always a viable solution.
Old Dec 19, 2004 | 09:49 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
I see people say this alot but people never say what the chamber size is on a 305??
What is the chamber size on a 305?
Even all my books just read 305 head 87-92. On the 350 heads they say valve sizes and chamber sizes.
Old Dec 19, 2004 | 09:59 PM
ljnowell's Avatar
305's had 58cc combustion chambers, 350's (L98) had 64cc. Typically, when someone says 350 heads, they are trying to pawn off 76cc (882, 993, etc) crap heads. The kind of stuff that I would kick someones butt for dumping any where near my garage. The last time I took a set to the junkyard the guy there gave me a dirty look. They are bad.
An overlooked, but really good choice for a 305 is the l98 corvette heads. The corvette heads had 58cc chambers with the 350 sized valves. A good combo for a 305.
Sorry I skirted your question. 350 heads got 1.94 1.50 valves, and 305 heads got 1.84 1.50 valves.
Old Dec 19, 2004 | 10:28 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
They do however make really good door stops and wheel chocks.....LMAO
but seriosly i wouldnt put a set of 882 or 993 heads on a 305 or a 350 as lj said they are crap ...
if it were my car and I wanted to upgrade something it would be the exhaust it will open up alot on that 305 with headers and a good flowing system
Old Dec 19, 2004 | 10:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Porting practice then a boat anchor. Works really well.
Old Dec 19, 2004 | 10:52 PM
THEGENERAL's Avatar
Yeah me and lj have a couple heads in my garage we are doing some heavy porting practicing work on now....
Practice makes Perfect....
Old Dec 20, 2004 | 06:58 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Sure 76 cc heads are great on a 305.
A 305 with a blower on top.
Actually I was thinking of using a 305/76cc head combo for a farm feild well pump. The low compression ratio would probably be great in this type of application.
Old Dec 21, 2004 | 01:20 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
LT1 heads are 54cc, and that's a "350 head"
...but if you're asking questions about whether a 350 head will give you more power over a 305 head on a 305...don't even THINK about messing with LT1 heads on your car.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
st.evel07
Aug 13, 2015 06:15 PM
