No Heat!!
Old Dec 20, 2004 | 11:11 AM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
No Heat!!
now that it's winter, this sucks....the engine is running at the right temp (no overheating nor is it running too cold) and the heater core was already replaced last year but i can't get any heat...well i get some but it might as well be AC...any ideas?? need anymore info??
Old Dec 20, 2004 | 12:35 PM
Morley's Avatar
Check for a kinked or misrouted heater hose. not too familiar with the earlier years...do you have a heater control valve?
Old Dec 20, 2004 | 12:46 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Could be a blocked heater core
Old Dec 20, 2004 | 12:57 PM
chio987's Avatar
Engine: 305 4bbl HO
o...i also forgot to add that the air gets warmer under acceleration and when i stop and idle the air gets colder
Old Dec 20, 2004 | 01:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Sounds like a blockage somewhere to me. Feel the heater lines. See what's warm/cold.
Old Dec 20, 2004 | 01:12 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
could be:
When under power the pump forces more through the mostly clogged heater core, and at idle it isnt pushing much through...
Unook a heater core core hose and blow it out with compressed air. I just did it today on a friends car. You should have seen all the crap that was in there
And his heat works again
Old Dec 20, 2004 | 01:15 PM
copperhead110's Avatar
the thermostat sounds like a suspect too.
the last time I had a thermostat problem. The car would warm up and be toasty while it was idling. As soon as I drove it far the heat would go away. This seems a little different than your car.
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
If the core was replaced just last year then I doubt its blocked already.
More than likely the coolant hoses are blocked, the valve is going, or the vacuume hose to the heater valve is bad.
Old Dec 20, 2004 | 01:41 PM
chio987's Avatar
Engine: 305 4bbl HO
ya, that's what happened to our 98 neon. the stat was falling apart and the new one fixed the problem. i'll check the hoses
Old Dec 20, 2004 | 01:43 PM
That was stupid of us to forget the stat. Can't believe I missed that one.
Old Dec 20, 2004 | 02:12 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
Re: No Heat!!
No one was stupid, he made it sound like the t-stat was working fine.
Old Dec 20, 2004 | 03:51 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Have you totally flushed out your cooling system. There could be air pockets from when you installed the heater core.
Old Dec 20, 2004 | 08:05 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
I ran into a problem like this when I hooked up a heater in my el camino. Where is your heater hose hooked up? I had the inlet threaded into the water pump like most 350's I've seen. I got no heat unless I was reving the motor. Brand new heater so I moved the inlet hose to the manifold and put a pipe plug in the water pump hole. Works awesome now.
have you moved hoses around at all? how was the heater working last winter? is all that vacume hose stuff still on your car? One of those "flapper valves" might be swinging open when you accelerate and closed when you brake? just an idea...
Old Dec 21, 2004 | 01:50 PM
I believe that the valve is probably the culprit I just remembered this:
A long time ago I had a heater problem because the radiator was low. My water pump had gone bad and was losing fluid thru the weep hole. Because the level in the radiator was so low, my heat didn't work.
BTW: I'm sure he meant "stupid" in the most positive way.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
