White powder on tail pipes?????????????
Old Jun 10, 2001 | 08:12 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I just noticed about a couple of weeks ago that inside my tail pipes there is a coating of white powder all over the insides of my tail pipes. I wiped it off and it has come back. I have never noticed it before so I think it just started doing it. I had the car in the exhaust shop a few weeks ago to get my new headers and cat converter welded up and asked them if they have ever seen it before on other cars and they said no and had no clue as to what it was. They then saw I had A Borla Stainless steel exhaust system and thay said maybe it was a coating on the stainless steel that was burning off UNTIL I told them I have had the catback on for two years and that the white powder just started to show up in the last two weeks. Anyone have a clue as to what it is????
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
[This message has been edited by john5.7 87Iroc (edited June 10, 2001).]
Old Jun 11, 2001 | 01:20 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ahh...you got the rare John Delorean model
Have you had the car smogged lately? Might reveal something.
Old Jun 11, 2001 | 02:03 AM
87RS402's Avatar
Snort it up and see what happens. You might have a decent processing facility there.
Old Jun 11, 2001 | 05:16 PM
SUPER-SPORT-CHEVY's Avatar
john5.7, Its possible it could be coolant.
Has the car gotten hoter than usual in the recent past? A head gasket could have started leaking went through the system. Its possible that it could have sealed its self up shortly after.
Thats the only thing i can think of.
SSC
Thats one nice camaro!
Old Jun 11, 2001 | 06:25 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
[This message has been edited by john5.7 87Iroc (edited June 11, 2001).]
Old Jun 11, 2001 | 06:26 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by 8Mike9:
</font>
Almost a year since last time. Get to do it in 2 months. Passed pretty good last time.
</font>
the day before I noticed the white stuff my fans stopped working and the my car got very hot didnt overheat though. I also have a very slight coolant leak somewhere for the last couplr years but haventpayed much attention to it since it was so slight. guess i should find it.
Old Jun 12, 2001 | 08:36 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I have seen cars that run extremely lean for one reason or another get that white powder in the pipes. I think it has something to do with what happens to the fuel when the engine leans out too much. Somebody I know explained it to me but I forget what exactly the reaction is that is going on when the engine goes waaayyy lean. You may have had this condition when your fans didn't come on and your car got too hot. The extreme high heat may have made it run lean and produce that white stuff.
Somebody will jump in and explain it better but I think this is what may have happened - unless you do have coolant leaking into the cumbustion chamber.
An idea........
Good luck...
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, Home-made cold air system w/ K+N cone, AFPR, TB bypass, AirFoil, !AIR, !A/C, !EVAP, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
Old Jun 13, 2001 | 07:25 AM
purpleworm's Avatar
If you are curious just pull the plugs out and check them one at a time. If one is white you have a bad head gasket. You will know if you are burning antifreeze.
FormulasOnly
Jul 23, 2018 08:47 AM
Fronzizzle
Feb 9, 2017 09:31 AM
cmichael
Exterior Parts for Sale
Dec 21, 2015 06:56 PM
Night rider327
Oct 9, 2015 09:25 AM
KCG
Sep 23, 2015 09:05 AM
