I HATE VATS!!!
Old Jun 11, 2001 | 07:14 PM
GTAsteve's Avatar
I HATE VATS!!!
Alright, I'm at wits end here guys. My VATS was acting up earlier this month so I decided to bypass it. I found the two wires coming down from the steering column and going into a clip and put a 3000 ohm resistor btw them like I read in the archives. That seemed to fix the problem, but I guess that was just an illusion my car wanted me to believe. Anyway, I go to try and start it today and it wont start...same as before. The security light goes on for about 2 seconds then goes off and when I try to start the car....nothing. The temp guage shoots up, thats about it. No flashing security light or anything like that. I really need some excperienced help on this one.
Old Jun 11, 2001 | 08:05 PM
GndPrx's Avatar
Is that the proper resistor value for your vats? Measure the resistance of the key and make sure that you need 3k or if you need a different value.
I went through this with my remote start having to bypass the VATS. I occasionally have the same problem you are describing, but only once in a great while.
L8rs
Carl
CarAudio Resources
Old Jun 12, 2001 | 02:07 AM
Omar's Avatar
Are you sure it's a VATS problem? Usually, when it's a VATS problem, the security light will come on and STAY on instead of going out after 2 seconds.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jun 12, 2001 | 06:50 AM
GTAsteve's Avatar
Yes I did check the resistance of the key with a digital multimeter. If it is not VATS what else could it be? Nothing else keeps the car from cranking at all sometimes and not others right?
Old Jun 12, 2001 | 11:37 AM
Mark W. Winning's Avatar
My Firebird was doing the same thing. I thought it was the VATS also, but as posted above, the security light did NOT stay on. This means is is probably not JUST the VATS. I put a meter on the crank wire for my starter. When the car was acting up, this wire was seeing very little voltage, hence it did not crank. I tried for days to find out why, but since the problem was not constant, it is difficult. I finally installed a BOSCH relay on the crank wire and have never had the problem again. The low voltage from the crank wire may not be enough to engage a starter, but it will trip a relay.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Jun 13, 2001 | 07:25 AM
GTAsteve's Avatar
Could you go into more detail on the installation of this relay. Thanks alot.
RS Reaper
Oct 17, 2018 07:52 PM
sammy52401
Nov 11, 2015 07:20 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
