PLZ Help! Car won't Start
Old Dec 21, 2004 | 04:13 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
Hi guys any help is apperaited.
I went outside tried to start my car, and the battery was completly dead, nothing.
I replaced the battery because it was bad....
Put gas in it.
The motor turns but does not start. What could be the probelm.
Could it have something to do with the cold, its the first time its been this cold since ive had the car, its like 14 degress today.
Plz help me. Thanx.
Old Dec 21, 2004 | 05:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What did you replace the battery with, a new fully charged one or a used one?
Old Dec 21, 2004 | 05:18 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
A brand new one, is it possible that the battery needs to be started before the charge is really good, because I cant turn on my radio, and the rotation sounds a little slow
When a first got the car I used to just run it, I thought the radio was broken, But then after I drove it around, the radio worked fine, I dont think there was enuff amps(or w/e it is I dont know about eletricity)
Anyways I want to pop start it but there is snow on the ground, and it is hard to push.
Old Dec 21, 2004 | 05:26 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I bet that your connections are not very good. It is best to have a large copper wire going from the ground terminal to the engine block, and another larger cable going from the positive terminal directly to the starter.
This will solve alot of no start problems. The starter requires lots of power and when the connections are good no power can travel.
Old Dec 21, 2004 | 05:29 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
What should I do bolt the copper wire to a nut that goes on the engine block, like and intake manifold nut?
And I could just get the copper wire from a hardware store right?
Old Dec 21, 2004 | 05:32 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
That should work, i bolted my ground cable to the side of the block right above the starter.
You should be able to get cable at a hardware store. Or cheaper at a electrical place. Ask for something around 0 gauge, 2 gauge might work for ground, but 00 gauge would work the best. I used 0 gauge, because thats all i could find at the time.
Old Dec 21, 2004 | 05:33 PM
TonyP455's Avatar
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
ok thanx alot man. I will try that as soon as possible, I need a ride to the store. Man this is gonna suck, I cant even get the car in the garge
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
