LT1 heads with 1.6 ratio roller rockers?
Old Dec 21, 2004 | 05:29 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I have a question about Al Lt1 heads and 1.6 roller rockers. Would i have interference problems with the valve covers running them with a XS262S .477/.488 cam? Will centerbolt and LT1 valve covers interchange? What are my options, i haven't seen any tall centerbolt valve covers.
Old Dec 21, 2004 | 08:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I think it depends on what type/brand of rockers you go with. Check with the LT1 guru's on camaroz28 to be sure. Many of them run the ProMagnums and the GM performance parts LT4 rockers under the stock covers. Although I too have not seen any tall centerbolt valve covers, all of the aftermarket ones have additional amounts of clearance under them. They don't have all the webbing and supports that the stockers do. I have noticed that companies are starting to mention this in their product description as well.
Old Dec 22, 2004 | 02:01 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Ok cool thanks! I did see a site where they had to cut the webbing/supports up to fit some comp Pro Magnum widebody rockers.
Does anybody know if the valve cover rails, are raised compared to standard perimeter valve covers.
Old Dec 22, 2004 | 02:48 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im using proform 1.6 aluminum rockers. They fit find, just had to take some pliers and bend the valve cover webbings, took about 5 minutes per valve cover, fits like a dream.
Old Dec 22, 2004 | 03:03 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Awesome pasky, thats exactly what i wanted to hear. :hail:
Now does anybody know if LT1 valve covers and centerbolt valve covers are interchangeable.
Old Dec 22, 2004 | 03:10 PM
pasky's Avatar
I imagine so, only difference between the lt1 and l98 valve covers I believe, is the oil check is on the passenger side and the breather valve is on the passenger on the lt1 covers. Not sure on what else, because I have rarely seen an l98 in person. I imagine they would fit.
Old Dec 22, 2004 | 03:36 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Thats what i thought too, thanks again!
midge54
Dec 27, 2019 04:14 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
