last report of school yr: how to change oil yourself
Ok it's the last report of the yr. and i need a good grade so can anyone help. I need to explain how to change oil on a car. and i have to be very descriptive. that means explain to the class like they are a bunch of dummies. can anyone give me the steps to complete a oil change. Thank you Thank you Thank you.
Yeah. Like all of you guys were born with the instinct to change a car's oil.
Give him a break. This message board was set up to HELP people, no matter how far superior you feel you are to him.
or her.. whichever it is.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
[This message has been edited by Enkil (edited June 12, 2001).]
89 iroc-z 305 tbi
Transmission: 4L80E/4L80E
Search the topic on this forum. A very similar question was asked several months ago.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Green,
57 has the right idea - search the message archives. Whatever you write, make certain you stress the safety aspect above all else. Warn about the potential for hot oil, parts, using the correct lifting and supporting means, and washing away the contaminated oil from skin and clothing afterward. You might as well get another gold star and outline the environmentally correct method for used oil disposal.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Later,
Vader
much apologies for my rudeness. I thought it rather funny though...I thought the guy was trying to make a joke. I mean its not that big of a deal on my car....
jack car up
have beer
secure car on jackstands
have beer
crawl under
remove the oil plug
go have beer wait 7-10 minutes
re-insert plug
add oil
beat ***** in road race
drunkenly add new garage door
jack car up
have beer
have beer
crawl under
remove the oil plug
re-insert plug
add oil
what a small world. I just wrote the same report like 2 months ago for 11th grade English. I got an A despite the fact the teacher hates me. Bitch. Anyway, I live in Livonia and your welcome to my paper if I can find it. If its not too late, e-mail me at DunawayD@twmi.rr.com Hope this helps you out.
<font face="Verdana, Arial" size="2">Originally posted by zerogauge:
jack car up
have beer
have beer
crawl under
remove the oil plug
re-insert plug
add oil
drunkenly add new garage door</font>
jack car up
have beer
have beer
crawl under
remove the oil plug
re-insert plug
add oil
Thanks for being courteous, though...
Later,
Vader
jack car up
have beer
have beer
crawl under
remove the oil plug
re-insert plug
add oil
jack car up
have beer
have beer
crawl under
remove the oil plug
re-insert plug
add oil
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, TH350 tranny with 2500 stall.
SLP 1 3/4" headers
Car: 99 Formula
Axle/Gears: 342
Same here, didn't mean to come off rude, I figured he/she knew how to do it, but was trying to save some work.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
At first I wasn't going to respond because I too thought that the post was a joke, but then after reading the above posts, I remember that what is easy or simple to me may not be for someone else.
I recall the previous post about changing the oil, and if I remember right, I don't believe the following points were made, so I'll include them here.
When I change my oil, I first make sure that the oil is at least warm (or hot if you can remove the plug without letting the hot oil spill on your skin). The oil will flow easier and faster.
Then I use a floor jack and put a jack stand under one wheel (lower arm), remove the drain, remove the jack stand and lower the car. I do this because I can get more oil out of the oil pan when it's lowered.
Some may disagree, but I fill my oil filter with fresh oil before installing it. The reason is because if it was empty, then it would take longer for the engine to develop full oil pressure. As you probably know, operating an engine without the proper oil pressure is bad. Since an empty filter will only take 2-4 seconds to fill up, it could probably be correctly said that that will do no harm to the engine. I've just gotten into the habit of doing it. If I'm going to error, I'll error on the side of safety.
If you've never changed the oil yourself, I'd recommend you do it before writing your paper. Experience, even if it's only once, will help you a lot with your paper.
Good luck.
//Stuart
Good luck.
//Stuart
i change the filter every other oil change because i have to borrow the nifty little tool to take the filter off, but i change the oil often...like on those lonely friday nights when i only have the company of a 6 pack
*grin*
*grin*
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
