intake q
Old Dec 22, 2004 | 06:51 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
intake q
hey guys. quick question here.
whats the difference between the stock 305 intake and 350 intake manifolds?
are they the same? do the 350 intakes have bigger ports?
Old Dec 22, 2004 | 06:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: intake q
What 350 are you talking about? The only 350 that came in f-bods was the L98. I am pretty sure the 305 and 350 TPI inductions were identical. I know for a fact that all TBI intakes for LO3's and LO5's were identicall. Other than that it is too hard to say without knowing what kind of stock 350 we are dealing with. There were about 329874384658465 (or around there) versions of the 350 produced over their 50+ year production span.
Old Dec 22, 2004 | 09:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Your info under your avatar says you have a carb'd 305. So if a carbed manifold is what you are talking about, a carb'd 350 was never put into a third gen.
Old Dec 30, 2004 | 09:34 PM
oh ya, sorry, i shoulda mentioned its not from a thirdgen. its actually from a suburban. but anyway, i know my carb will fit good on it since the top of it does look kind of like my old 305 one...
Old Jan 1, 2005 | 02:06 PM
ta
Old Jan 1, 2005 | 02:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Canadian LG4 intakes were cast iron, L69 were aluminum. The US aluminum LG4's were the same as the L69.
The aluminum intake was better than the typical cast iron 350 intake. I haven't seen the cast iron LG4 intakes personally, so I don't know how good or bad they are.
Typically, the intake performance can be improved by some gasket matching and general clean-up. Unless you're "building' this 350, you don't "need" a better manifold, but the aftermarket types typically do a little better than the factory cast iron types.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
