Just one wheel spin...Why ??
Old Jun 12, 2001 | 09:34 AM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
I was thinkin every time i make my car wheels spin ...it only spins the driver side ..but a friend of mine with a formula 350 ...it spins both?and what are the diffs tween a limited slip and a normal one..i have a 82 firebird 2.8 2bbl how can i know which ratio is my rear end??thanks.
Old Jun 12, 2001 | 09:38 AM
purpleworm's Avatar
You have an onpen rear or a single track rear, whatever you want to call it. A limited slip will sense a wheel is spinning and apply power to the other tire so they will both push the car. Pretty well the same thing as a posi.
Old Jun 12, 2001 | 09:39 AM
purpleworm's Avatar
You have an open rear or a single track rear, whatever you want to call it. A limited slip will sense a wheel is spinning and apply power to the other tire so they will both push the car(both spin). Pretty well the same thing as a posi.
Old Jun 12, 2001 | 12:30 PM
irocbsa's Avatar
You most likely have a 3.42. In fact if I was a bettin man I'd wager a good sum that says that you have a 3.42. That's what came in an overwhelming majority of v6 cars after 85 (????) I believe. I think before 85 they were using 3.73s as well.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 12, 2001 | 12:55 PM
mtx28's Avatar
jack the back end of the car up, spin one wheel, and counnt the number of turns the axle makes(which gives you a ratio, axle turns:wheel turns).. it may not be exact, but will give you an idea if its 3.42's or 3.73's
  • 83 Z28-- not a pretty site to look at, 200k miles and im sure it was treated like a rental car every day of its sad life(before i got it).. sold, thank the lord
  • 74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Old Jun 12, 2001 | 04:44 PM
82camaro's Avatar
Car: 82 camaro SC
In 82 open 3.08's were common with the v6
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jun 12, 2001 | 11:06 PM
MrJ's Avatar
MrJ
<font face="Verdana, Arial" size="2">Originally posted by purpleworm:
You have an onpen rear or a single track rear, whatever you want to call it. A limited slip will sense a wheel is spinning and apply power to the other tire so they will both push the car. Pretty well the same thing as a posi.</font>
Just to clarify, an posi rear IS a limited slip rear. Same thing, two different names. 'posi', or Positraction, is the GM name for a limited slip rear.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
ported TPI setup
Built on Wednesday
Old Jun 13, 2001 | 02:54 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
Put two sticky tires on the back of your bird then neither one will spin.
Old Jun 13, 2001 | 03:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Irocbsa, no 3.73 found it's way to the V6's from the factory... but oddly enough, a 4-cylinder f-body ('82-'85) with a manual trans got a 3.73/open/drum axle!
Sammy, a definate performance upgrade would be putting in an axle from an '85-'89 V6 with an automatic transmission; but yeah, you still won't have a posi. For posi, look to the '83-'84 Trans Am (or Z28) with engine code "G" and a manual transmission. That's a 3.73/posi/disc rear axle... same one I put under my v6 Firebird last August.
Mtx, won't he have to divide (or multiply) by two, since he doesn't have a posi? I think he'll have to divide.. for instance, for one turn of the driveshaft, the one tire will spin 6 times... divide by two, and that's 3.. so he'd be near a 3.08 gear. Or am I wrong? I'm pretty sure you have to divide by two (unless you've got a posi axle).
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
