ZZ4 Shortblock Questions?
Old Dec 22, 2004 | 10:31 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
Is the ZZ4 shortblock set up the same as the L98? What I mean is...Are the pushrods the same length, will i need a cam buttom, or anything else? If anyone has done this coversion, let me know any of the differences between the motors, besides the 4 bolt main and the steel crank. Thanks.
Old Dec 22, 2004 | 11:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The ZZ4 and L98 used the same block casting. There aren't any other significant differences with regard to setting them up.
PM rods, hypereutectic pistons, and oil baffle are about all that's left - along with cam & heads, of course.
Old Dec 22, 2004 | 11:12 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The L98 that was third gen. equipped is 2 bolt mains, ZZ4 is 4. Minor difference, just clarifying. Not that it matters in the selection of actual components....
Old Dec 22, 2004 | 11:15 PM
five7kid's Avatar
He indicated he knew the ZZ4 was 4-bolt main, which I assumed meant he knew the L98 was 2-bolt main.
I had actually started to list all of the differences, then pared it down to what you see.
Old Dec 23, 2004 | 09:09 PM
pellmanm's Avatar
Car: 1989 GTA
Can I use the same timing cover without needing a cam button, and can i use the same oem style lifters?
Un-related, is the stock distrubuter have a cast iron gear, because the LPE 219 cam has a cast iron gear?
Old Dec 24, 2004 | 12:21 AM
five7kid's Avatar
Factory roller cams are retained by a plate that is bolted to the block. No button required.
Factory roller cam equiped engines use a "melonized" distributor drive gear. It has an anti-wear surface treatment.
Old Dec 24, 2004 | 12:23 AM
five7kid's Avatar
ZZ4 also has a main stud mounted oil pan baffle.
lt500r55
Sep 1, 2021 01:30 PM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
italiano67
Aug 31, 2015 06:04 PM
redmaroz
Aug 16, 2015 11:40 PM
