192cc aluminum superflow heads on ebay for 250each
Old Dec 23, 2004 | 04:15 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
ebay click supposely 64cc (seems awful small)
and 475 a pair.
ebay click
supposely 67cc (seems even less likely)
flow numbers
edit guess I was away for a while..
Old Dec 23, 2004 | 04:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
https://www.thirdgen.org/techbb2/sho...ight=superflow
Old Dec 24, 2004 | 07:46 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Unless you have a makita die grinder, and lots of patience, I'd stay away.
Tom bolted those on his 406.. (blower, cam, etc) and got like some crazy low HP figure. like 2xx. He says its the cam.. I"m thinking the heads.
-- Joe
Old Dec 24, 2004 | 08:47 AM
AllGoNoShow's Avatar
Looking down the intake port, I have to say, there is not much more room between the common port wall and the valve guide boss then stock heads. My world s/r heads almost look better. If you ever look at AFRs, Trickflows, etc. this area is rather large because thats where all the air flows.
I agree with ^ -unless you plan on 20-40hrs of porting, I wouldn't invest in these heads for top performance. If the flow #s are correct, however(and you can get the seller to gurantee them), they would be a step up from stock heads. But don't think your getting AFRs, TrickFlows, Brodixs type preformers for half the price.
deracer
Apr 11, 2016 12:04 AM
evilstuie
Feb 28, 2016 03:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
z28addict8490
Aug 7, 2015 08:48 PM
