Went out the car and here are the results..
Old Dec 24, 2004 | 09:00 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
I had spark, tried to jump the fuel pump by putting 12volt+ to the g port on the aldl connector and whammo didn't hear crap coming from that fuel pump....
so what is there todo now?
Shane
Old Dec 24, 2004 | 09:22 AM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Re: Went out the car and here are the results..
One of three things.
1) Listen to peoples advice.
2) A search.
3) The obvious.
Old Dec 24, 2004 | 09:24 AM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
replace the relay before you go and drop your rear axle.
Old Dec 24, 2004 | 09:35 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok i found 6the problem, took out the ignition control module had autzone test it and it was fried.... thanks tho guys....
Old Dec 24, 2004 | 10:54 AM
luke4907's Avatar
Engine: TPI350
I thought you said that you had spark? My ICM died on me and I had no spark. If I had known I would have suggested it...
Old Dec 24, 2004 | 11:18 AM
ljnowell's Avatar
Did you start a whole new thread for this? I thought you said you had spark? Do you know what spark is?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
