roller rockers rubbing..
Old Dec 25, 2004 | 06:55 AM
STIFFLER's Avatar
Went to put some of my Trickflow 1.5 RR's on my G1 Trickflow heads and noticed that they are going to rub.. I put Comp Cams 986 springs on them due to my choice of cam.. I don't really want to grind them down or anything.. what are my choices?
Old Dec 25, 2004 | 08:16 AM
ede's Avatar
ede
check push rod length and valve train geometry along with the locating method used for the rocker as well as what method the rocker uses
Old Dec 25, 2004 | 08:26 PM
STIFFLER's Avatar
I have a pushrod length checker but what do I need for the geometry for the valve train and where do I find the other info as for the method the rockers use?
Old Dec 25, 2004 | 08:58 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
"therckid wrote on 12-25-2004 10:03 AM:
i am tired of you ed, open my darn thread back up now... i need fregign help and when you close the one thread i had that stayed on topic your abusing your rights as a moderator.
Open the darn thread.. leave me alone, treat me as any other noob member, and it might be better...
Sahne"
Thats so sad, go Ed!
Old Dec 26, 2004 | 06:24 AM
ede's Avatar
ede
trick flow should of provided info on the rocker locating method they use, i'd guess non -SA so you'd want non-SA rockers. as for checking geometry that should of all fell into place with the push rod length check. do a search here or look in a comp or lunati catalog and you'll find some good pics or drawings of how the rocker should contact the valve.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
