Foaming in the coolant?
Old Jun 13, 2001 | 11:01 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
This isnt on a thirdgen, but it is a general engine question so maybe you guys can help out.
My mother's 91 Plymouth Acclaim with the 3.0 V6 has like a bubbling foam forming in the anti freeze. My father thinks there's a head gasket leak, and exhaust gases are getting in the coolant. The oil isn't milky and there doesnt appear to be oil in the coolant.
Old Jun 13, 2001 | 12:58 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
How much fluid is in it? I know that sometimes if the fluid is low, it can foam up when hot. Also, when was the last time it was changed? It's possible that you may not have a very good mixture and it just needs to be replaced. Those are just some thing off of the top of my head.
Hope that helps!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Jun 13, 2001 | 02:16 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
My father and I checked the coolant last night. It was low, but not drastic. Maybe an inch or 2 below the neck. Honestly, I don't remember when it was last changed. Probably wouldn't be a bad idea. Although at the end of the summer we're gonna fix everything on the car for good...get rid of it!
No, I don't see my 53 year old mother in a new F-body. Oh well.
Old Jun 13, 2001 | 02:19 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If it has no other symptoms of a blown head gasket, i would assume it is old funky coolant and do a full flush/refill. If it comes back, then you have some kind of a problem. If not, it'll be that much easier to sell the car.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jun 13, 2001 | 06:55 PM
Enkil's Avatar
Here's a thought...
When you filled the radiator, did you get the water out of a new garden hose? They seem to have some type of detergent or SOMEthing, but it foams up for a while after you get the hose.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 14, 2001 | 06:45 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
It always gets filled with 50/50 antifreeze.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
