What is the purpose for the crankcase breather?
Old Jun 14, 2001 | 12:26 AM
1991camaroRS's Avatar
I just recently put on the open breater (best 30 bucks i've ever spent) and i havent put on an after market crankcase breather...my question is what is the purpose of this part? Is it majorly important or is it just something thats there and should really not be given a second glance. I still plan on getting an aftermarket one, but i wanna know if i need to get one soon or later..thanx
1991 Camaro RS (Red)
-TTops
-Custom quad exhaust
-Edelbrock 14x3 open air element
Old Jun 14, 2001 | 01:10 AM
Enkil's Avatar
The crankcase breather can be mostly forgotten about... The pcv should be replaced semi-regularly though.
Check the breather filter. If it's black, dirty, oil stained, etc., go ahead and replace it with a new one. It's only a few bucks. And while you're at it, you might as well get an aftermarket one.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 14, 2001 | 08:09 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I pitched my PCV valve in favor of a second breather.
To answer your question, it's function is to remove the positive pressure that can build up in your crankcase as a result of blowby. Without it, you'd have positive pressure in the crank case, which can cause all sorts of leaks in valve cover gaskets, oil pan gaskets, etc.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Pac J
May 17, 2020 10:44 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
