Wil strokeing an engine change the compression?
Old Jun 14, 2001 | 07:50 AM
Alan84TA's Avatar
If you stroke 350 to 383 with the same heads etc will your compression change any?
Old Jun 14, 2001 | 08:36 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
yep. You have more swept volume and you are reducing it to the same previous size. It would probably go up from .3 to .4 points depending on the chamber volume.
[This message has been edited by jcb999 (edited June 14, 2001).]
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
