VATS?????
Old Jun 13, 2001 | 05:37 PM
SpeedStar's Avatar
VATS?????
I have heard you guys talk about this quite a bit and I can't figure out what VATS is. Can some one enlighten me on the subject. It seems to be talked about most on the Firebirds. Is that all it came on?
1991 Camaro Z-28 305ci 230hp
1985 Camaro Coupe 331ci 300hp
http://www.geocities.com/speedstar38...Speedstar.html
Old Jun 13, 2001 | 07:10 PM
Enkil's Avatar
VATS stands for Vehicular Anti-Theft System. There's a very easy way to see if you have it.
Does your key have that little black nugget in it? That's a part of the VATS system.
Here's how it works:
There are two wires running two the ignition. When you stick your key in, that black nugget completes the circuit. Well, the nugget is a resistor. The two wires run to a module that eventually runs to the computer. Well, the computer measures the resistance in the wires, and if it matches a stored value in the computer, it'll let your car start. Otherwise, it's disable for a few minutes. Unfortunately, the VATS is easy to bypass, and there's only like 15 different values anyways, but.. it's a good start. heh
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 14, 2001 | 11:01 AM
SpeedStar's Avatar
Yep my key does have that and I knew that it was for the Security for the car but I just had no Idea what it was called. Thanks for the reply thats all I needed to know.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
