car wont run coughs gas out of throttle body
Old Jun 13, 2001 | 09:38 PM
bad camaro RS's Avatar
when i try to start mt 89 rs 305 tbi it tries to run then dies and spews gas from throttle body? cant figure it out? replaced cap rotor fuel filter and egr and computer still does it it use to do it from time to time now it does it everytime any ideas
Old Jun 13, 2001 | 10:18 PM
87Iroc-z's Avatar
Car: 1987 Z28
Transmission: 700-R4
My dad and i had a similar problem with our chevelle. It spitting raw fuel out the carb. Turned out the distributor was off 180.
Old Jun 13, 2001 | 10:21 PM
yeah it seems like it out of time but i havent messed with timming and it was doing it from time to time then run fine nows it does it all the time
Old Jun 13, 2001 | 10:27 PM
87Iroc-z's Avatar
Car: 1987 Z28
This may be a stupid question but i just want to get the obvious out of the way. Are u sure you installed the rotor in the right direction?
Old Jun 13, 2001 | 10:29 PM
yes it was doing it before new cap and rotor
Old Jun 13, 2001 | 10:34 PM
87Iroc-z's Avatar
Car: 1987 Z28
Only thing i can really think of right now is timing. Sorry i cant be anymore helpful.
Old Jun 13, 2001 | 10:57 PM
see this is actully my buddies car i said timming to but the ting that has us baffled is for the last month is jus did it now and then and would run fine any other time and started to get worse to now it jus wont run coughs and shoots gas from tb thanks for the effort
Old Jun 13, 2001 | 11:04 PM
Vader's Avatar
Say it with me....
¿ Timing Chain ?
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 13, 2001 | 11:20 PM
Enkil's Avatar
I was thinking that too actually...
Doesn't matter how good your distributor timing is, if the cam timing's off no amount of distributor timing is going to fix that.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 14, 2001 | 07:04 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
A cooked catylitic converter or a leaky intake valve are two possibles, with the leaky intake valve not likely.
Old Jun 14, 2001 | 11:26 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
If there are no codes, do a manual inspection of all your sensors.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
