Is this the knock sensor...
Old Dec 27, 2004 | 01:02 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
under my TPI plenum near the fuel pressure regulator, there is some kinda sensor plugged into the manifold....
what is it?
for some reason i think i disconnected the two wires that connect to it.
Will this cause it to not start?
shane
Old Dec 27, 2004 | 01:08 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
this is definately not the knock sensor
dont have a tpi but could it be the water temp sensor?
why did you disconnect it?
nebu.
Old Dec 27, 2004 | 01:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Do you know what a knock sensor is?
Old Dec 27, 2004 | 01:10 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
It's an air temp sensor...
Fix it.......
Old Dec 27, 2004 | 01:11 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
would it stop the car from starting?
Old Dec 27, 2004 | 01:12 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Why the hell is it unplugged in the first place?
Old Dec 27, 2004 | 01:14 PM
12secformula's Avatar
Car: 94 Z-28
Man the knock sensor is on the block, how would it detect knock in the plenum? Why such a silly question, wouldnt iy have been easier to plug it back in than ask that question?
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
i dont know i justnotice a pair of wires lying around near it,and saw where they prolly went...
because this temp sensor was disconnected....
Old Dec 27, 2004 | 01:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Do a seach under this kids name. You will see that this is on par with the rest of his ill-advised, pointles posts.
Old Dec 27, 2004 | 01:18 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Old Dec 27, 2004 | 01:19 PM
No but it needs to be fixed.....also, you said earlier it was under your plenum and plugged into the manifold. Which is it? It's either the sensor underneath the plenum or the sensor that is in the "manifold." The plenum and manifold are not the same.
Old Dec 27, 2004 | 01:20 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
He is quite entertaining though...
I do feel sorry for his car.
Old Dec 27, 2004 | 01:21 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
its plugged into the plenum....
i'll go get a pic
Old Dec 27, 2004 | 01:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I have said this before, I will say it again:
Shane, take your car to a garage. Have a real mechanic fix it. Someone who knows what the hell they are doing.
bru333's Avatar
Car: 1987 Camaro SC
i'll go get a pic
Where have I seen that post before...
Maybe, but it's a legitimate question. If this were anyone else several people would be glad to help. But because it's shane everyone is pissing on him. Yes he could have done a search but it was a "to the point" question and I don't mind answering it. I am one of the first guys to give him crap when he's being stupid but I thought this question was different.
Old Dec 27, 2004 | 01:23 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
For shoots and giggles, I think ede needs to be the one to lock this one.
i'll go get a pic
Then it's an air temp sensor...just fix it and your done. Don't need a pic.
Old Dec 27, 2004 | 01:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
No, this question really isn't that different. A normal person would have the common sence "ok, car doesn't start, lets see if anything looks amiss..oh here's a plug, I wonder where it came from? Oh, right here perhaps. I wonder if that was the cause?" And so on. It's called troubleshooting. A little common sense to begin with. From there, yes, I can see a post from him and I wouldn't be so ragged.
That's fine if you want to answer it, thats up to you.
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Attached Thumbnails Is this the knock sensor...-air-temp-sensor-004
Old Dec 27, 2004 | 01:29 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Attached Thumbnails Is this the knock sensor...-air-temp-sensor-003
Old Dec 27, 2004 | 01:33 PM
Car: 94 Z-28
I see the plug you are talking about and it appears that the one wire is cut off. Am I correct and if it is, why?
Yes it is different...it can be difficult to do a search for something you dont have a name for. You could have just answered the question and moved on. He was troubleshooting and found the broken wires. Maybe you should find some other form of entertainment for today. The thread actually belongs in on the TPI forum.
Old Dec 27, 2004 | 01:34 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok yeah the thing is, i dint know which orders the wires go in....
Old Dec 27, 2004 | 01:35 PM
Looking at those pics all you have to do is take the sensor out and resplice the wires back on and clip the sensor back in. You dont have to remove it from the plenum. Unclip the sensor...
Old Dec 27, 2004 | 02:29 PM
ljnowell's Avatar
Shane, BTW, you were supposed to post some pictures of that big block stuff the day after christmas, what happened with that? Another one of your lies, d00d?
Old Dec 27, 2004 | 02:31 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
i actually goto pick the thing up monday, i missunder stood him and he meant after the holiday by like after new years also. so......
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
he still cant figure out what is wrong with his car....here is his latest thread started moments ago....https://www.thirdgen.org/techbb2/sho...99#post2131699
Old Dec 27, 2004 | 02:32 PM
THEGENERAL's Avatar
how are you going to do that when you said you are leaving to go back to florida on the 30th of december.....so.....
Old Dec 27, 2004 | 02:49 PM
ede's Avatar
ede
ok you got it, hope sahne doesn't tell on me
The Red86Z's Avatar
Car: 86 Z28/91 dodge stealth rt TT
dude.... im sorry i meant "d00d", TAKE YOUR CAR TO A SHOP
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
