Timing/Knocking Problem!
Old Dec 27, 2004 | 11:38 PM
Annihilator's Avatar
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
OK, here goes.... I hear what I believe to be knocking at 0 degrees base timing. So we experimeted a bit.
We put it 4 degrees advanced and left the ESC connector undone. There was absolutely NO PINGING whatsoever. However, when I restarted it with the esc connector plugged in, I heard the faint detonation at partial throttle, like I usually hear. I don't have a engine code, and it runs fine so I don't think its carbon buildup.
This is on a 89 LO3 w/ true dual exhaust and a K&N filter.
Am I incorrect in saying that the Knock Sensor might be weak or bad? The other thing is posibly a bad ECM. What do you guys think?
Adam
Old Dec 28, 2004 | 12:24 PM
Car: Caprice
Engine: 5.0 305 LO3
TTT
Old Dec 28, 2004 | 12:26 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
it could be the knock sensor it self or the esc module going out.
Old Dec 28, 2004 | 05:30 PM
Car: Caprice
Engine: 5.0 305 LO3
Ok, and where is the ESC module? In the distributor?
Old Dec 28, 2004 | 08:27 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
you can test the knock sensor by tapping on the block near it while it's running with a timing light on it. You should see it retard a few degrees.
Old Feb 15, 2005 | 07:04 PM
Car: Caprice
Engine: 5.0 305 LO3
Old Feb 15, 2005 | 07:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Let's keep it all on one thread.
https://www.thirdgen.org/techbb2/sho...hreadid=276149
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
