no sound whatsoever
Old Dec 28, 2004 | 10:11 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
no sound whatsoever
hey guys,
another problem with my car. First let me thank you guys for your help each time. Anyway, about 2 days ago i was out all day driving in my car and it ran great cause it was a lil cool out so the car was cool. anyway, i parked the car and about 4 hours later i went to go out and i turned the key, it sounded like it was about to start but it didnt. i tried again and now when i turn the key nothing happens, nothing. no sound whatsoever. The battery is fine, i even tried a jump anyway. could the starter have just gone?Im takeing the car to the mechanic (dont know how) i wanna know what to tell him since im a kid and dont want to get ripped off. Sorry for rambling but me without my car is just not cool.
- thanks in advance, Adam
Old Dec 28, 2004 | 10:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Do you have power to anything at all? Or is it just the starter motor that doesn't want to go?
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
same thing happened to me a couple of times.... check ur grounds.... i dunno what it is but its intermitent for me and afetre a lil while power comes back on its own
Old Dec 28, 2004 | 10:25 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
well,
everything works, besides the car , actually, the radio, windows lights, all good just no start.....is it the starter? that i can afford....lol barely.
Old Dec 28, 2004 | 10:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
How about if you try it with a screwdriver across the 2 terminals? It may be as simple as a solenoid going/went south.
Old Dec 28, 2004 | 10:29 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
how do i do that? this may sound stupid, wheres the starter and these "terminals"
Old Dec 28, 2004 | 10:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
On the starter, there is the solenoid. The starter itself is on the passenger side of the engine. If you look down, you will see a big round metal thing. It looks like a coffee can. That is the motor. Just above it is the solenoid. It is a little plastic cylinder, about 3" in diameter, maybe 5" long. You will see a big terminal where the battery cable leads. You will also see a smaller terminal to the right of it (closest to the engine block). Take a long screwdriver and basically bridge those 2 terminals.
Old Dec 28, 2004 | 10:33 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
wheres the starter, under the car or in engine bay? sorry, im bad with mechanical work....but thanks for being patient
Old Dec 28, 2004 | 10:34 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Edited the post. Now includes location.
Old Dec 28, 2004 | 10:37 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
thanks, this making post after post is crazy but thanks sooooo much, im so excited im going out now...
Old Dec 28, 2004 | 10:38 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Here's a picture (not my engine). This is viewing from the passenger side, rear. Circled in black is what/where the starter motor is.
Old Dec 28, 2004 | 10:49 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
too dark, ill try in the morning, but if it starts when i do this? does that mean i need a new starter? or just the solenoid? on that pic, what two things to touch together?and thats kinda hard to see whn eninge is in the car right?
-Adam
Old Dec 28, 2004 | 10:50 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
If it does start, replace the solenoid. 2 little bolts hold it to the motor. It's about a $10 part at most part stores.
Have a messenging service? Contact in sig.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
