back-up lights sensitive/(acting up)
ive got an 86 z28/automatic. and the thing is that when i put it in reverse, i noticed sometimes the backlights come on and sometimes they don't. well, the shifter has a slight bit of play in the reverse position. and when i push it all the way back until it is almost in drive, they go off. but when i put it all the way forward so its up against park, they come on. im only talking about a slight bit of play in between shifts. is the play supposed to be there and somethings just not conecting, or is the play the problem. either way how do i fix it, its driving me crazy. thanks
Car: 82 camaro SC
Neutral safety switch in the console is probably getting worn out. The shifter might be getting a little worn as well. The safety switch also runs the reverse lights. Pop the console and make sure it's connected good(a bunch of wires plug into it).
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkim bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
