Possible Collapsed Lifter....Need Opinions
Old Dec 29, 2004 | 07:44 PM
RedGTAWSU's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: L98 350
Ok...so i've been having problems getting my vavles properly adjusted. Mainly cause I can't destingquish the noises under the hood. I know I misadjusted the rockers once, then a second time getting them all too tight. Finally got them adjusted right tonight and found a knock in the upper part of the motor. I know it's not the bearings...i've had that knock before and know what it sounds like. After the very last time i adjusted them i started hearing a this knock AFTER the motor was WARM. Same thing today. Also, while adjusting the #1 cylinder exhaust vavle the following happened....after the final 1/4 turn after the noise was gone it knocks once or twice then goes away. At idle it's not very noticeable unless the motor surges. The knock gets worse with RPM's. I found the rod on this cylinder to have scratches on one side of the "ball" on the lifter side of the rocker. I switched rods with another rocker, and the knock happened again in the same place after the last 1/4 turn.
Now....I think and hope it's just a collapsed or damaged lifter, and I hope it didn't damage the cam.
Anybody agree? disagree? other ideas?
Ryan
Old Dec 29, 2004 | 09:26 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If it is a roller lifter, swap it out. If it is a flat tappet cam it is likely done
Old Dec 29, 2004 | 09:31 PM
RedGTAWSU's Avatar
Engine: L98 350
so do you think it's the lifter?
Old Dec 29, 2004 | 09:33 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
If it is a factory roller lifter I would buy 1 new lifter, 1 new pushrod, and 1 new rocker . Very hard to punch out a factory roller cam. It can be done but it take a bunch of abuse to do it.
Old Dec 30, 2004 | 11:29 AM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
if you adjusted a rocker TOO tight it will scrape the camlobe with so much force it willl seize or flatten the lobe.
thats why i think solid cams are so scary, with a hydr. lifter you have always some play, but solids??uhuh!
Old Dec 30, 2004 | 03:40 PM
ede's Avatar
ede
isn't collasped lifter secret code talk for i got a noise i don't have any idea what it is? have you checked for exhause leaks or injecter noise, to name a few?
Old Dec 30, 2004 | 03:43 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yup, a collapsed lifter will sound like a ticking. Exactly the sound of an exhaust leak or compression leak (perhaps a spark plug is loose). Check for leaks, check your rockers for ticking. Worse case scenario, pull the intake and take a look at the lifters.
Old Dec 30, 2004 | 10:03 PM
RedGTAWSU's Avatar
Engine: L98 350
I've already eliminated it being a rocker noise. I made all the rockers tick/rattle, then tightend them till the tick stopped and another 1/4 turn.
It too loud and metalic to be a injector noise. The noise it definately two metals things hitting in the wrong way, and it's too high pitched and high in the motor to be a bearing.
By process of elimination, the noise started after i had driven the car about 2 miles with the rockers way to tight. Below is the method I used prior to the 2 mile drive.
With the motor off...got each cylinder to TDC one at a time. Then tightened each till there was no play in the rod. What I failed to realize is that it's when there is no up and down play, and not to the point of no side to side play. After getting them that tight...I went another 1/4 turn.
So they were definately too tight.
Old Jan 21, 2005 | 12:21 PM
pasky's Avatar
I have the same problem im trying to figure out, it doesn't sound like a rod, its coming from up top.
Old Jan 21, 2005 | 02:27 PM
RedGTAWSU's Avatar
Engine: L98 350
I'm going to investigate more....compression check, maybe check out the timing chain....will update.
Ryan
Old Jan 21, 2005 | 02:53 PM
pasky's Avatar
Im pulling my cam out, have a feeling I got a wiped lobe.
Old Jan 21, 2005 | 05:45 PM
RedGTAWSU's Avatar
Engine: L98 350
If you could somehow get a good sound clip or video tape with sound....I'd like to hear it to see if it's similar. Then when you take your cam out and find it's a lobe i'll know that's what it is on mine. There are serious plans for this motor....so I might just start them now. Was going to wait till summer, but might as well get it out and start now.
Ryan
Old Jan 21, 2005 | 06:52 PM
pasky's Avatar
Wish I could, but I already have it torn down. Just need to pop my oil pan gasket and timing cover and im gonna fix this **** once and for all. Your problem sounds 100% like mine. My motor seized one day and I loosened the rockers enough to get me home. Re-adjusted them at the house and bent 2. Replaced lifters and pushrods and I got this noise that I can barely hear at idle but the minute I rev it a little bit, clack clack clack.
Old Jan 21, 2005 | 08:04 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
pascal, didn'y you just install that darn lt1, how did you seize it already?
Old Jan 21, 2005 | 08:17 PM
pasky's Avatar
Wow......just wow.....
Old Jan 22, 2005 | 12:49 AM
pasky's Avatar
Well I just pulled the cam and I really can't tell. My very back lobe (my lifter that collapsed was the #7 exhaust, so may be it) looks like it has been run down a little and the lobe doesn't look symetrical, one side has more lobe, the other lobes look symetrical, so this might be my problem.
Old Jan 22, 2005 | 01:40 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
but you'll have it running soon right? all that work wasn't for nothing.
Shane
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
