Raw fuel [LIQUID] coming out of tailpipes!
Old Dec 31, 2004 | 08:49 AM
seanjuan's Avatar
Car: 1981 monte carlo/sold 1984 z28
Engine: 350 w/carb no mods
Transmission: th 350 w/shift kit & 2800 stall
Well, I just had a carbed 350 thrown into my car and when I started it the yesterday, I walked around to the back because I saw a just little bit of bluish-black smoke from the exhaust. It was dripping a lot of gas out of both tailpipes. Is my stock carb not burning the fuel? carb is supposed to be computer controlled but I dont have the computer and wires so its doing it's own thing right now. I also need to know if I switch to non computer controlled carb and distributor will that solve my problem? Thanks for the help.
Old Dec 31, 2004 | 09:54 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
are you positive that it's gasoline? that's an awful long way for gasoline to travel. it's very likely condensation (water) that is just clinging to cold pipes.
or else I'd say you have a serious overfueling problem, and/or an ignition dealie.
Old Dec 31, 2004 | 09:59 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
first off the carb doesnt burn fuel. my guess is with the changes in temperature that it is 95% likely to be condensation. now you may be smelling gas and assuming the the liquid is in fact gas itself. your motor may be running rich which might cause that gasoline smell but i highly doubt that gas is coming directly out of the tailpipes.
Old Dec 31, 2004 | 11:24 AM
seanjuan's Avatar
Is it possible for a carb not to mix the gas with the air and just pour it into my intake? But it should still burn when it gets into the engine right? If I stand by the back of the car I end up smelling I spilled gas on myself. The smell is just like gas straight from the pump.
Old Dec 31, 2004 | 11:33 AM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Easy to tell. After running the car for a minute or two, shut off the car, have a fire extinguisher handy, and try to light the SMALL pool of liquid with a bbq lighter or match. You'll know if its gas or not.
Old Dec 31, 2004 | 11:36 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well, if you have pulled the wires off the carb, you have no mixture control soliniod anymore. So yeah, it's going to run rich and poorly. I think what everyone thinks though. Probably condensate coming out the tailpipe - and it smells like fuel because it's running too rich.
And yes, you'll need to get a non CC carb on there along with a vacuum or mechanical advance distributor before it's going to run right. There's no in-between. Either it's CC or conventional. Take your pick.
EDIT: And please people, don't tell anyone to light thier car on fire!! They might actually do it!
Old Dec 31, 2004 | 11:52 AM
seanjuan's Avatar
I got a non cc Accel distributor I wanna use but who makes good carbs for street/strip daily drivers? I was looking at edelbrock 600 electric choke. Is any certain brand good for cold starts?
Old Dec 31, 2004 | 12:08 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Sounds like a nomination for a Darwin Award .
Q: What's the last thing the ******* said?
A: "WATCH THIS!"
Old Dec 31, 2004 | 12:28 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
really ? or were you being facetious ?
I don't see how trying to ignite a small puddle of condensation is going to hurt anyone. Some of us just need to prove it to ourselves, i guess.
Old Dec 31, 2004 | 12:40 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
ok now alls you have to do is get yourself some spark plugs, screw them into the tail pipes.. get some coils lol jp
Old Dec 31, 2004 | 02:29 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
let the 'gas' drizzle out of the exhaust pipe into those disposable plastic cups or similiar, if its gas it will eat right through it almost instantly.
Old Dec 31, 2004 | 02:53 PM
Cadillac's Avatar
Just bustin' on ya since I figure to meet you next year.
It'll all become clear at that point.
Ghettobird52
Jul 5, 2024 11:18 PM
NBrehm
Aug 25, 2015 11:49 PM
gta power
Aug 13, 2015 06:15 AM
Kaweh
Aug 9, 2015 02:54 PM
