i need help with a bearing question
Old Jun 14, 2001 | 10:09 PM
nelliesIroc's Avatar
I am installing my scat crank into my block and I am using clevite 77 bearings. I measured the clearance and i got .003" on all of the mains. My question is in the chiltons manual it says that the clearance on #1 should be .001 - .0015 and .001 - .0025 on all the rest, but in the clevite application catalog it says that the clearances can be from .001-.0036. So which should i believe or are they both wrong and if so what are the correct clearances?
Old Jun 14, 2001 | 11:19 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I had this same basic question a little while ago. I have the same bearings, and read the same specs, in Haynes and Clevite that you have. I have read numerous times that .0025"-.0028" is optimum, but you can go as high as .0035". Although, that large of a clearance is for 8000-9000rpm engines.
My point is that I SCRUBBED the bearings before I put them in. I'm used to getting metal shipments at work with a protective layer on them. I thought this about the Clevites. Well that "layer" is a soft, lead based coating on there to help trap metal shavings so that they don't tear up the bearing/crank journal. I washed that off and opened up my clearance to .0035" by doing so. Stupid me. So now I get to buy new ones. About $20. Could've been a more expensive mistake I guess. I remember that the #1 should be about the same to. As long as it isn't over .0025".
Old Jun 15, 2001 | 06:09 AM
ede's Avatar
ede
i'd try for .0015 to .0025 clearance i nthe mains. you can buy a set of +.001 OVERSIZE bearings and mix shells to get the clearance down a little. considering how cheap a set of bearings is it isn't a bad idea. are you checking clearance with plastigage? if you are i wouldn't consider it real accurate, not to .0005 anyway. best to check clearances with a dial gage, mikes, and snap gauges.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 15, 2001 | 07:08 PM
ok i got some new bearings but was wondering how many times you can torque the main bolts? They are a new set of ARP bolts but i have already torqued them twice checking the clearances.
Old Jun 15, 2001 | 08:49 PM
Guest
Guest
Posts: n/a
I wouldnt worry about the bolts, you havent run the engine yet so they havent seen any engine loading, and they havent seen any heat cycling yet either.
anesthes
Mar 10, 2016 10:35 PM
anesthes
Aug 26, 2015 01:37 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
