Is there a better way to stop this oil leak?
Old Jun 16, 2001 | 08:07 AM
Golden80's Avatar
The drip comes out of the drain plug. The oil pan was punched in at some point in it's life. I've been using RTV to seal the bolt on to stop the leak. I've tryed using the GM drain plug gasket with the little rubber peice and other numerous gaskets but it still drips. Just slower. The only way I can see of getting rid of the drip is to replace the pan.
Matt
Old Jun 16, 2001 | 08:32 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Hard to say without seeing why it is leaking. If it is leaking because of a bend/seam in the sealing surface, maybe you can fill it in w/ epoxy putty or something. Otherwise, try to describe it a little better cuz i don't really get it.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jun 16, 2001 | 10:44 AM
Enkil's Avatar
You can get these piggyback plugs.. Normally I absolutely hate them but in your instance it might help. It's really a plug inside a plug.. The bigger plug is slightly larger than the threads on the pan, and you force it in with the intention of never removing it again, and only unscrew the smaller one from then on. You could screw in the bigger one and seal it with some epoxy.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
IROCtometal
Sep 20, 2015 11:08 PM
LittleFranks
Sep 17, 2015 12:22 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
drathaar907
Aug 6, 2015 04:20 PM
