HSR connections??
Old Jan 3, 2005 | 09:00 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
HSR connections??
I tried to find this info on the net. No luck. I'm currently Deployed in Kuwait so it hard to call holley. does anyone know if the HSR w/C950 has connection for the 700R4??
Mods: if this isn't the right place for this sorry. Didn't know where to put it.
Old Jan 3, 2005 | 09:28 AM
kevinc's Avatar
Car: 1982 Z28
Check around in the DFI and ECM forum, the info you need is related to the Commander itself and not the HSR intake.
I did a quick search on 'commander OR 950' and came up w/ this...
https://www.thirdgen.org/techbb2/sho...mmander+OR+950
Have a safe tour, get home in one piece, and Thank You!
Old Jan 3, 2005 | 10:33 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: HSR connections??
[i] does anyone know if the HSR w/C950 has connection for the 700R4??
Mods: if this isn't the right place for this sorry. Didn't know where to put it. [/B]
The Holley throttle body will have a place to hook up the TV cable from the 700r4 but the Commander 950 cannot directly control the lockup funtion. There are aftermarket kits to do it but I'm not familiar with them, or you can run it with a non-lockup converter.
Good Luck over there!!
Old Jan 3, 2005 | 11:20 AM
Car: 1992 Camaro RS
thanks for the help. I'll look for that part. thanks again
InfernalVortex
Apr 20, 2021 11:31 AM
bplessy
Sep 30, 2015 12:14 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
