Rocker Arm Question
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Self aligning rockers have "nubs" on the valve stem side of the rocker arm that straddle the valve stem and keep it aligned. You cannot use guide plates in these applications because the pushrod will bind.
Non self aligning rockers or "regular" rockers use guide plates for larger lifts.
ambainb
Apr 25, 2016 09:21 PM
