View Poll Results: Are you stumped like me?
Yes, I would hate to be you.
0%
I have an idea!
100.00%
I have the answer!
0%
Voters: 1. You may not vote on this poll
A real stumper of a sound
Old Jan 4, 2005 | 04:58 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
My problem is very odd and elusive. On Friday I started to hear a noise that sounded like a person patting himslf on the shirt. I have traced it with a stethoscope to the bottom of the engine. It is most audible once warmed up. It reminds me of spark knock, but it is not. I have taken it down to 10* timing at 93 octane with no avail. Next I thought of a loose lifter. Set the valve lash again, same problem. Next I made sure that nothing on the engine was hitting the fender etc. That checked out. Re torqued the header bolts, same problem/noise. Check spark plugs, looks good, just hot.
I have been monitoring all of my sensor readouts, all reads normal. No oil or coolant is lost and oil pressure is fine. Could it be a timing chain? I did notice a few hiccups when adjusting the timing. it would go up two degrees for a 1/2 second then regular. There is no shake at all when it is idling or reving or driving as a cylinder not firing might present.
I next thought it could be a loose bolt on the tranny/flywheel/clutch/bellhousing. Well one of the top tranny to bell housing bolts was finger tight, the other top one was 1/2 way out. The pressure plate/disc was a little misaligned, but all of the clutch and flywheel bolts were correctly torqued. So I started the engine with nothing after the flywheel. Noise still exists.
Look in my sig. for additional car info. Any suggestions on where to go from here would be appreciated.
Old Jan 4, 2005 | 10:13 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Maybe try pulling your belt(s) off after warming it up and see if the noise is being caused by misalignment and the belt riding up the edge of an accessory then slapping down. It may seem to come from inside if the snap is bad enough to make it to the crank.
Just a thought after everything else fails.
Jp
db057
Jan 10, 2020 08:55 PM
FormulasOnly
Jul 23, 2018 08:47 AM
jrdturbo
Mar 31, 2016 02:58 PM
PestilenceIV
Sep 22, 2015 07:39 PM
Blue419
Sep 10, 2015 01:03 PM
