Tools for valve seal replacement.
Old Jan 5, 2005 | 04:30 AM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
I want to change my valve seals, and could use a tip on where to buy a decent tool to do the job. I have a valve compressor, but it's the kind you need to get the head off to be able to use. So I need a tool to be able to do it with the head on the engine.
DO you have a pic of how it looks? Maybe I could find it locally, but need to know what to look for.
Also, I wonder if there are a tool to hold the valve in place, perhaps just a hose from a tire with two connectors on it, either way I dont have anything usable.
Finally, it would be best if I could buy everything, included the seals from one place, since shipping usually double the cost.
Old Jan 5, 2005 | 05:04 AM
ede's Avatar
ede
looks sort of like a 2 jaw puller with a screw hand wheel arrangement. most any place ought to have one. i'd bet autozone has one in their rent a tool program. use compressed air to hold valve up and in place, or string put in through the plug hole.
Old Jan 5, 2005 | 09:24 AM
tilstad's Avatar
Is this it? This one is $89.90 at Autozone:
Competition Cams Valve Spring Compressor Chevy Small Block V8 And 90 Degree V6 Tool
Old Jan 5, 2005 | 09:27 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
That is not the tool referred to. That looks like a shaft mount spring compressor. The typical one has a star shaped wheel on top and is about 4 inches tall.
Old Jan 5, 2005 | 09:28 AM
tilstad's Avatar
I can't see how it's supposed to be used though...
Old Jan 5, 2005 | 09:29 AM
tilstad's Avatar
You mean like this? This is the "regular one", I need one that could be used without taking the head off...
I have one that looks almost like this one though..
Old Jan 5, 2005 | 09:34 AM
tilstad's Avatar
I found this one, this is it, right?
Proform Stud Mount Valve Spring Compressor. For 3/8" & 7/16" Rocker Studs.
Old Jan 5, 2005 | 09:36 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
ede's description is accurate. It looks like a 2 jawed gear puller with a star shaped wheel on top. The jaws grab the spring and the wheel is spun to squeeze the spring together. Very easy to find at auto store since it may be the most popular type.
Old Jan 5, 2005 | 09:39 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I have had no luck with the lever type compressors like the one shown. Sometimes there is not enough room in the engine bay to use this tool. The one I describe is much cheaper and much more compact. This makes it easier to use most times. Expect to pay about $35 (us) for the small one.
Old Jan 5, 2005 | 09:45 AM
tilstad's Avatar
Ok, it sounds good, but this was all I could find, at least at autozone.
Do it have a specific name?
Old Jan 5, 2005 | 09:51 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I don't have a specific name but I do have a part number. My unit is a K D tools number 2078 hope this helps.
Old Jan 5, 2005 | 10:02 AM
tilstad's Avatar
Okey, thanks, that helped alot, I found several on the net selling them , on ebay too.
Now, the second tool I need would be something to keep the valve from falling into the cylinder. I have heard about some hoses supposed to be used with compressed air, but I don't have a compressor. Is the pressure from a tire enough?
I have a tiny tiri compressor/inflator, could it be used? Normally it takes ALOT of time to pump up a wheel, so I don't know if it's the best thing to do. It could take a real long time then. The thing about a rope inside the cylinder sounds scary to me though..... Any ideas?
Old Jan 5, 2005 | 11:22 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I personally use the compressor, however, If you dont have a decient one, there is nothing wrong with the rope trick, just make sure you have a nice long rope so that there is plenty still sticking out of the spark plug hole. You want no chance of the end slipping in the hole.
Old Jan 5, 2005 | 11:55 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
Sears has these tools also
Old Jan 5, 2005 | 06:39 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
I bought this at Advance Auto right off the shelf for about $10 and had no problems with it. And they sold the spark plug/air adapter for about $3, also worked good.
Nick McCardle
Sep 10, 2015 08:36 PM
tgp1990
Sep 4, 2015 06:24 AM
mrdevontay
Sep 2, 2015 08:04 PM
SlowAZ28
Sep 2, 2015 05:19 AM
