lopy idle
Old Jun 17, 2001 | 04:45 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
lopy idle
got a 91'Z-28 5.7L, while driving last week the car started to idle rough then finaly lope while idleing and jerking forward when I have it in drive.It feels like a cylinder is missing, I've checked the plugs & wires,cleaned up the distributor cap, still has the problem.several days ago I cleaned my IAC with carb cleaner( might be the problem?) my car was running fine for 4 days after the IAC cleaning & now this. I sprayed throttle body cleaner around the intake manifold to find any leaks, none found. any help will do.
Old Jun 17, 2001 | 07:03 PM
One Eyed Jack's Avatar
My car does that too, but then it usually stalls out during htat. Its my oxygen sensor. I just need the part and my uncle needs a free weekend. He works 2 jobs, and he's contracting the construction of his own million dollar house. He has no time. And Ive got no ramps to get under my car with.
1992 Pontiac Firebird (stock)
- 305ci V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
  • Aiwa CDC-MP3 head unit
  • Rockford Fosgate 360a2 amp
  • pair of 12" MTX Thunder 5000s in a custom box
  • Pioneer 3-way 6x9s, soon to add more more more!
Old Jun 17, 2001 | 08:48 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
alittle more info, when I start it up, hot or cold it will idle & drive fine for 30 seconds then it will start to get lopy and missing.
Old Jun 17, 2001 | 09:37 PM
rezinn's Avatar
Jack..
You really don't need to elevate your car, soaking in penetrating oil and heating up the threads of the sensor(by running the engine for a couple minutes) will be enough to just get the sensor out with a ratchet.
For some reason I have seen people against using o2 sensor sockets, but they have worked great for me in the past. An open end wrench will work well from below, just put it on from the top before you try.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
