Doing oil pan and rear main
Car: 1994 Jeep Wrangler
I have a 2 piece rear main and i was wondering how much to torque down the oil pan bolts, the rear main bolts, and the bolt that holds in the oil pump. The oil pan gasket is the expensive fel pro blue 1-piece on that comes with new bolts. Thanks
Does your oil pans have the stiffener rails? With stiffeners, the 1/4-20 bolts should be 10 ft/lb, and the end (5/16-18) bolts should be 14 ft/lb. Without rail stiffeners, the torque should be 7 and 12 ft/lb, respectively, to prevent rail distortion and potential leakage.
Rear main cap bolts should be 70 ft/lb.
Navy8125
Aug 21, 2015 09:32 AM
