which loctite???
Old Jan 6, 2005 | 10:19 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
which loctite???
Doing reassembly of valve job.
Which loctite should I use on:
head bolts
intake bolts
header bolts
water pump
other bolts in general like A/C brackets and P/S brackets
The guy at the O'Reillys sold me high temp red, but not sure if that's what I should be using or not!
TPIS says I should use silicone on front and rear of intake instead of normal gaskets. Is the red stuff that says for making gaskets, what I should use there?
THANKS,
Craig
Old Jan 6, 2005 | 10:42 AM
ede's Avatar
ede
PST for anything that goes to water
headers none or antiseze
thread locker for accessory mount bolts, or none
you're confussing, you ask about what to use on bolts then talk about gaskets. red ought to work, i use ultracopper for the china walls.
mgilorma
Aug 5, 2009 12:37 PM
SERPENT99
Brakes
Sep 26, 2005 10:39 PM
phess11
Mar 18, 2005 04:39 PM
Zap Racing
South Central Region
Jan 8, 2005 09:11 AM
Fredzep
Apr 24, 2003 06:37 PM
