loctite red or blue?
Old Aug 5, 2009 | 11:30 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
I have my engine down to the long block for a cam swap and some other freshing up. Which loctite should I use, red or blue?
Old Aug 5, 2009 | 12:02 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: loctite red or blue?
what exactly are you looking to loctite during the install? There's not too much you'd want to use that stuff on during a cam install.
in general: blue if you would at some point think you may need to remove the part, red if you don't ever plan on removing the part.
if we're talking rtv, rule of thumb: black for areas with oil, blue for areas with coolant/water, red/copper for high temp.
Old Aug 5, 2009 | 12:37 PM
mgilorma's Avatar
Car: 90 RS
I was going to use it on the spider holdown, cam retainer bolts, and cam sprocket bolts. I've read in a couple places that you should use it on the cam sprocket bolts and as for the other place, since I just wanted it for reasurrance.
leighgrils
Oct 9, 2015 09:38 PM
TheExaminer
Sep 28, 2015 02:28 PM
Linson
Sep 21, 2015 01:08 PM
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
MORREALE5
Sep 13, 2015 09:01 PM
