200 Iron eagles on carbed L98?
Old Jan 7, 2005 | 12:13 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Guys I have been searching info about different cylinder heads for a long time. Trying to decide which ones to get.
First off, money is a key factor.
I switched my L98 over to carb. I plan on keeping it this way.
What I want is just a good street/strip car. I would like to be in the mid to high 12's. Nothing too radical.
I want to keep it a 350 for now, may go to a 355 or 383 later, but just stock bore right now.
I can get some 200 dart iron eagles 64cc with springs to match my cam for 800-850 from a local connection. I would like to just do a head and cam swap. Maybe a comp xtreme hyd roller grind. Im looking at the 276 or 282 grind.
I will be building my 700r4 and going with a 3000 stall.
My intake is a single plane and has a range of 2000-6500.
The rest is in my sig.
Do you guys think the darts will be a good decision? They flow 262 intake at .500 and 175 exh at .600.
Im trying to get a good plan, but keep money in mind.
thanks for any input guys/gals.
Old Jan 7, 2005 | 12:33 PM
ljnowell's Avatar
Re: 200 Iron eagles on carbed L98?
Why not spend the extra 150 and go aluminum. The Trickflow Kenny Duttweller heads outperform most others, and only cost 1050.
Old Jan 7, 2005 | 12:43 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: Re: 200 Iron eagles on carbed L98?
I accually had the trickflow in mind also. My contact will give me a great deal, If I guy heads, cam, timing chain, rr's, and push rods.
I can probably get the dart for 750-800 and get the other stuff cheaper than jegs or summit also.
I have never asked him about the trickflows. He might be able to get them also. Both the dart and trickflows are my picks. I just dont want to spend over 2g's for heads and cam swap.
Do you know any place to buy the trickflow other than summit for a good price?
Old Jan 7, 2005 | 12:49 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
Sounds like a great set heads for what your looking for.If money is a concern check out ebay,ive bought a few sets of heads on there with great results.the last set were new trickflows complete for 750.cant complain at that price,and ive seen darts like the ones your looking at sell as low as 625 new.
Old Jan 7, 2005 | 01:01 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have not ever bought anything off ebay, But before I posted, I check for the darts and trickflows. No great deals right now. I will have to keep and eye out for them.
Old Jan 7, 2005 | 01:41 PM
Car: 1983 Z28
Engine: 383
Racers outlet usually has good deals on ebay.I picked up some protoplines 200's for 675 shipped.
Old Jan 7, 2005 | 01:55 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I will check them out.
What do you guys think about my plans. I should be able to reach my goals with either set of heads?
Old Jan 7, 2005 | 02:48 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
hey, if you do get new heads, can I have your L98's?
Old Jan 7, 2005 | 08:45 PM
Damon's Avatar
The Iron Eagles are good heads. Way better than stock L-98 castings. Not the best heads on the market, but good for the price (you can get them cheaper on e-bay or if you buy bare castings and put them together yourself from parts).
How good are they? I would put them on par with a set of Vortecs but without the hassles of needing a Vortec-style intake and the annoying lift limitations of the stock Vortecs.
Old Jan 10, 2005 | 08:07 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I think I will hold onto them, but you should be able to pic a set up cheap on the classified board.
Old Jan 10, 2005 | 08:09 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I will probably end up going with the trickflow's. What HP/et's do you think I could get with the trickflows on a L98 with a xtreme comp 282 hyd roller cam?
Old Jan 10, 2005 | 10:10 AM
Car: 1987 Trans Am
Engine: tree-fiddy
Thanks, I'm just looking for something cheap(free) to play around with porting and doing springs and stuff to learn.
Old Jan 10, 2005 | 11:11 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
If thats the case, then check your local machine shops or junkyards. They should have some 305 castings or some 70's smog castings you could get cheap or free. It wouldnt be worth the shipping to you for what you need. Even if I gave them to you.
Old Jan 10, 2005 | 11:16 AM
Car: 1983 Z28
Engine: 383
those L98 aluminum heads are the same ones they use on the ZZ4 engines arnt they?
I wouldnt call em cheap
Old Jan 10, 2005 | 11:21 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Vette's got the alum's. F-bodies were graced with the iron version.
I second the notion to go to your machine shop or something. That's what I did. They gave me a few 882 castings to practice on.
Old Jan 10, 2005 | 11:32 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
If they were aluminum vette heads, then I would still keep them. But yes they are the iron ones.
Old Jan 10, 2005 | 01:10 PM
Car: 1987 Trans Am
Engine: tree-fiddy
Well in the great City f Dallas the only machine shop around that I know of is City motor supply, and they don't give out anything.
Old Jan 10, 2005 | 02:05 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Even if you found a cracked head, you could pratice P&P or spring replacement. Im sure someone has a set of old usless heads. Check a wrecking yard also.
Might be worth a drive out of town.
Wish I could help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Nick McCardle
Sep 10, 2015 08:36 PM
rjcme
Sep 5, 2015 01:23 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
