How do I disconnect this??
Car: 89 IROC-Z
Engine: 383
I need to remove the wiring harness from my car and all that's left is the wiring that goes into the car for the ECM. How do I open up the weather pack connector that goes through the frame??
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
--RPM Racing--
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
If you are talking about the connector that is located on the passenger side it's not really a connector. It's a 'pass through'..Just found this out a few weeks ago. The wires continue right into the passenger compartment with out a disconnect. However you can remove the 'pass through' very easily from inside the car.
HTH
HTH
Car: 89 IROC-Z
Engine: 383
Yeah I meant the pass through.....thanks...I was trying to figure out a way to remove it from outside. I'll look from the inside tonight.
