I don't know how to change a rear main, but mine is leaking :(
Old Jan 8, 2005 | 12:52 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
Holy cow, I am dumping a quart a day of the new 0-30 syn!!! I need to get this fixed ASAP!
What would you reckon it would cost if i took it to a mechanic, vs. if I did it myself? I don't have a jack or jackstands so I have to figure that into the cost.
Old Jan 8, 2005 | 01:14 PM
ede's Avatar
ede
sure it's the main seal, few other places in the area will leak
Old Jan 8, 2005 | 01:26 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
phone around and ask some shops.They go by the book so they can only charge what the book gives them for hours.they can give you a quick estimate i'd say
Old Jan 8, 2005 | 04:23 PM
Parrydise7's Avatar
We just bought a 1969 Chevelle, at a pretty good price because the rear main seal was leaking.
We got the car home and started poking around. The oil pressure sending unit was so loose, I could unscrew it by hand. Now that this problem is taken care of, this 350, with 130,000 original miles, doesn't burn or leak a drop of oil.
Listen to Ede and make sure you know what's leaking.
Old Jan 9, 2005 | 09:59 PM
Project's Avatar
Car: 85 Camaro Z28
anyone have a ballpark or clue what I'm looking at? At $5 a quart this syn. is getting EXPENSIVE
Old Jan 9, 2005 | 10:02 PM
Parrydise7's Avatar
Did you read ede's post?
Old Jan 9, 2005 | 10:45 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
My money would be on the rear plenum seal. Mine was bad when I bought the car, and I had to dump 5 quarts in it to get home from jersey.
Old Jan 9, 2005 | 11:37 PM
Project's Avatar
Car: 85 Camaro Z28
yah i read it, unfort. it is sunday night and there isn't a shop open
I don';t have a jack or jack stands right now so it looks like i'm going to be handing it over to some jerk and paying premium
Old Jan 10, 2005 | 12:42 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Or spend $16 on a pair of jackstands at the local parts store. A jack is like $40 for a decent one, though they can get quite pricey.
You're going to need that stuff eventually. You can't even work on your brakes or change your oil without those things!
Not only that, but you'll pay that in just one hour of labor at a shop!
Old Jan 13, 2005 | 03:05 PM
Project's Avatar
Car: 85 Camaro Z28
k they are purchased!
How do I go about changing? I used search I just need a step by step Thanks guys /cheer
Old Jan 13, 2005 | 04:14 PM
91Z28-350's Avatar
How do you know it's the rear main? You need to drop your tranny, so you're going to need more tools than just a jack and jack stands. You're going to need some big *** jackstands too, not the rinky dink 2 ton stuff.
You should find out for sure first, cause it's a bitch if you take it all down and find that it's not the rear main that's leaking.
customblackbird
Aug 15, 2021 10:16 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
