need help. problems
Old Jun 18, 2001 | 12:24 AM
82 firebird's Avatar
need help. problems
I have an 82 firebird with a 305 105,000 miles. i disconnected the ecm new holly 650 and a stock disttributer disconnected all pollution control junk. first problem vibration car vibrates when parked and reved but only when i let off the accelarator. also when timed to correct timing engine does seem to miss at idle 600 rpm--when timing is advanced the miss at idle is gone but vibration seems worse -also when advanced car accelerates more quickly but engine bogs at full throtle- ok first question when i am advancing the timing my engine revs up and not down right??? also about the torque converter i relize it will not lock up since there is no ecm but could this be causing some vibration?? and i know most of you are going to tell me motor but the motor does not vibrate when i am outside manually pushin the gas i can only feel the vibration if i am sitting in the car revving the engine. any comments would be appreciated at least what way do i turn the distributer to get more power turn it so the engine revs higher or turn it so it revs lower. right now it is set at 6 degrees btc where it should be. but i want more power without the vibration and to be able to open the throttle all the way.
Old Jun 18, 2001 | 09:49 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
First thing you need to try and do, is figure out if the vibration is due to an engine miss, or an engine balance issue. A 20 year old car could be in need of a new harmonic balancer, torque converter, cooling fan, etc.
But start with the easy stuff first, do the tuneup thing..plugs, cap, rotor, wires, etc.
I don't think the cause of the vibration is due to no lockup.
Old Jun 18, 2001 | 12:34 PM
I did complete tune up car is in mint shape body wise new carb and ditributer only 105,000 miles on it-shocks drivetrain all in mint shape been stored in garage only driven about 1000 miles per year for past ten years the only real problem i have is with the tranny it does'nt slip and hits all gears hard but does leak tranny fluid from the pan and about 5 years ago when i bought it it had a mild shift kit put un it. when i look at motor i see no vibration but can feel it sitting in the car when i let off the gas parked so i am thinking it may be something with the tranny. motor only seems to miss if i advance my timing but only when i go full throttle driving. when timing is set to factory specs it does not miss at all but at idle the engine does lope up and down a little but i think that may be do to the holly carb 650 if i turn the idle up to 800 there is no miss but if i leave it at 600 it lopes up and down until i drop it in gear.
Old Jun 18, 2001 | 01:37 PM
ede's Avatar
ede
does the ecm control the distributor on that car? if it does you'd need a non ecm controled hei distributor.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 18, 2001 | 07:12 PM
distributer and carb are completly disconnected from ecm 650 holley and remanufactured distributer out of a pre 1980 car with vaccume advance hooked up to carb- i Am thinking the vibration is from either flywheel torque converter- and that holley 650 i have is pumping to much gas for the heads when advanced and that the 650 carb wont idle right when timed correctly because the jets are to big. so i turn uo my idle and it runs great other than the power thing. it will still chirp my 50s on dry surface from stop. maybee i am at max power and need to put my 350 in it?
Theman0188
Aug 31, 2015 07:42 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
