Something broke in my motor On my way to work. Please offer advice.
Old Jun 18, 2001 | 11:56 AM
Todds1987iroc's Avatar
I was driving my iroc this morning and had just slowed down to go around a sharp curve and was four gear. As I shifted to fifth the engine Seemed to miss and was down on power. Within about 10 seconds I started to hear something banking from the engine. after about 1.5 minutes this became louder and I really became concerned. I drove back home and poped the hood and the sound seems to be coming from the top of the engine. tonight I am going to pull the valve covers and check al of the valve. The oil pressure and temperature did not change when this happen and did not change on the 20 mile trip home after this happened. Please help if you can. Sorry about being long in my explaination.
1987 Camaro IROC-Z w/ 305 tpi/5-speed/9 bolt 3.45 gear/L98 Corvette heads/ T.E.S. headers/ LT4 production cam/ 1.6 rockers/ Flowmaster exhaust/ K&N filters/ MSD coil/ & other free mods.
1969 Camaro with '96 350 vortec truck engine with many mods.
2000 Chevy Silverado 4X4
Dale Earnhardt... NASCAR's greatest Champion
Old Jun 18, 2001 | 01:08 PM
EVILFACE's Avatar
Possible blown head gasket or intake. Anything leaking?
Evil's 88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element, MAC Lower Control Arms and Panhard bar
Old Jun 18, 2001 | 01:13 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
An actual banging noise coming from your engine is not a good sign. It could be anything from a rocker that backed off/broke, broken piston/bottom end parts, or best case, perhaps an accessory like your alternator or compressor had a bearing go and has something whacking around. You need to figure out exactly wher eth noise is coming from, then it should be more obvious. I also really wouldn't drive anymore until you know what it is, as driving with a rocker off, etc isn't gonna be too good for your engine.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jun 18, 2001 | 01:18 PM
ede's Avatar
ede
i'd pull the belt off the engine to eliminate everything it drives and pull the valve covers to see broken valve train parts plus to see if each valve opens and is getting oiled.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jun 18, 2001 | 08:54 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sounds like a bent/broken pushrod. Pull off the valvecovers.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jun 18, 2001 | 09:45 PM
Tonight I pulled the valves covers, The drivers side first and found the problem. The #3 exhaust rocker arm had come off the valve and bent the push rod. When I put the corvette heads on I did not use self-alining rocker arms and they needed them. So tonight I put on the leftover set that I got from the Vortec motor in my that is in my '69 Camaro. Thanks for the advice.
Mickeyruder
Sep 2, 2015 02:45 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
slade5612
Aug 11, 2015 07:19 PM
