Trick flow or fast burn heads
Old Jan 9, 2005 | 07:35 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
which head should i go for ? Mod's done to Engine. Its a Rebuilt 1992 center bolt head 30 over, 350 Engine, LT4 Hot cam, springs,24lb injector,Holley stealth ram, shorty headers.I want to make as close to 400HP as possible. Thanks for the help
Old Jan 9, 2005 | 08:12 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Get the Trick Flow, the Fastburns will require a special intake manifold.
Old Jan 10, 2005 | 06:59 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I have a Holley stealth ram on my engine now,Really not sure if it would fit that intake either
Old Jan 10, 2005 | 07:21 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
The Fast burns won't fit the HSR you have now. Holley just released a Vortec base for it.
Old Jan 10, 2005 | 09:38 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Or go with teh Dart/WP Sportsman II heads - they have the fast burn chamber and are available either cast iron (like mine) or aluminum --- and use "standard" SBC manifolds (not the Vortec type).
Old Jan 10, 2005 | 09:50 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Are you saying the teh Dart/wp sportsman II Aluminum are better then trick flow Aluminums?Or is it possible to make about 400hp with either head?
Old Jan 10, 2005 | 12:54 PM
ljnowell's Avatar
I dont see the sportsman II being a better head than the trickflows. THe last time I looked at flow charts, the trickflows outflowed them from .200 lift all the way to .700 lft.
Old Jan 10, 2005 | 01:09 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
the trickflows defenitly. they are good heads especially for the price you can find a set for and should get you to 400 hp.
im using an older set of the 23 degree trickflows and will be around 450hp (hopefully)
Old Jan 10, 2005 | 06:46 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
what kind of setup do you have,If you dont mind me asking Is it anything like what i have?
Old Jan 10, 2005 | 09:45 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
basics are:
forged 383 10.5:1 CR
trickflow 23 degree heads
custom comp cam .544/.555 lift 230/236 duration 112 lsa
holley stealthram
dd2000 says thats good for 487 hp and 491 tq but thats pushing it. im guessing around 450-460 flywheel hp and 480 flywheel tq.
but i always have my 150 shot
Old Jan 10, 2005 | 10:07 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That's a very nice looking cam you got there CamaroRUS . I think you will have a very stout platform.
Old Jan 10, 2005 | 10:15 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well thanks stek....it took a genius to find the right one but with some help i managed
dabronx...that cam is nice but you could go slightly bigger, unleashing even more power. but i can understand not wanting to swap cams again. if you need any help just ask. im sure stekman would love to help too if you asked nicely enough
Old Jan 11, 2005 | 06:28 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Every once and a great while ljnowell and I actually agree on something.
The sportsmans are NOT better than trickflows. I spent 5 years married to sportsmans.. Now I use trickflow.
-- Joe
Old Jan 11, 2005 | 07:16 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I thank all of you for the info you gave me so far,Its been a big big help,The cam i didnt do to long ago i did it when the motor was out of the car, i really dont want to do a cam again so,Im going with a set of 1.6 roller rockers, That should give the hot cam a little more lift.If i could get the car into the low to mid 12s, ill be happy
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
