broken vent controls? only defrosts vents work somtimes..?
Old Jun 19, 2001 | 01:01 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
this is weird,lately I've noticed that no matter what mode my vents are set to, all the air blows out from the defrost vents,then other times it all goes back to normal and works fine!! WTF!? a strange voo-doo curse or a common f-body problem?
Old Jun 19, 2001 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Common problem. Try searching the archives.
JamesC
Old Jun 19, 2001 | 07:06 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Most probable cause is the vacuum switch "manifold" on the back of that switch... do you hear a vacuum leak at all? Even if not, it can still do it. An easy way to fix this (so I've heard) is to pull that manifold off the back of the switch and swab the insides of each of those tubes with vaseline. Or if it's wose than that, you may have to "custom fit" the manifold back on there like I did. Either way, you DON'T want to have to replace that manifold, but shouldn't have to anyways... The vacuum manifold I'm speaking of is on the backside of the A/C control head, so you'll have to get to it by removing the control head (not completely), or remove your stereo and get to it from there. The manifold is held to the switch by 2 of those "press-on" lock washers, and can just be pried off. Just put a rag or something down in there first, cuz if you loose 'em...
KAM
Old Jun 19, 2001 | 07:27 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Kam is 100% correct. I just had my 92 Camaro unit go bad. Turns out the 5 vacuum port manifold was loose. NAPA wanted $11 for a new one but I stopped by my A/C guy. He did not have the correct one but gave me a similar one. I took the center pin (holds the whole unit together) out of the one he gave me and installed it in mine. She tightened up nicely and works perfect. Be warned, that pin in the center is a
b i t c h to get out! I had to cut the guts away from the pin on the new unit to get it out without damaging it.
later
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
[This message has been edited by Rob P (edited June 19, 2001).]
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
