Felpro intake gaskets
Old Jun 18, 2001 | 09:20 PM
jsbz's Avatar
Im putting my 350 TPI Back together.The intake gaskets have steel block offs where the exaust crossover are.What will happen if I use these gaskets?
Old Jun 18, 2001 | 09:34 PM
Guest
Guest
Posts: n/a
On one side, I cant remember offhand which side, the EGR gets its exhaust from. If you block off that side, the EGR wont be doing its job anymore.
Other than that, it doesnt matter.
Old Jun 18, 2001 | 09:50 PM
jsbz's Avatar
Will I need a new prom if my egr is blocked off?
Old Jun 19, 2001 | 12:09 AM
Guest
Guest
Posts: n/a
Possibly... some cars deal with it ok, some dont. It would probably be easier to put a hole in the metal plate on the gasket. Its easy to figure out what side, just take a look at which side of the manifold has a passage that leads all the way into the manifold.
Old Jun 19, 2001 | 07:43 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Hmm. My felpro kit came with the steel block-offs separate, so I just did not install them. Maybe you got the wrong kit? I think I used a kit for a 2bbl intake, not the full TPI kit with the whole smathering of gaskets. I always reuse my plenum and runner gaskets.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
