Any differents beside the price of these Rocker Arms
Subscribe
Jan 10, 2005 | 10:07 AM
1 Proform, roller rockers Small Block with Centerbolt Valve Covers, 1.6 Ratio, 3/8'' Stud, Self-Aligning, 16/pkg $189.99
2 Crane gold roller
1.60 Ratio; 3/8'' Stud; LT-1 & LT-4; Self-Aligning $319.99
3 Scorpion Roller Rockers
1.6 SBC 3/8 Self-Aligning Rocker Arms
Center Valve Covers 86+up $247
Any help would be great!Thanks guys
Reply 0
Jan 10, 2005 | 11:01 AM
If you are going to shell out the money for Crane golds, save a bit and get Comp Pro magnums. They are lighter and stronger than aluminum counterparts. To boot, they are steel, so they have far better long term usage than alum.
Reply 0
I've used 2 of the 3.
Had Crane Golds for 5 years. Never had any problems with them.
The Scorpians were loud as **** and I'd never buy them again.
Valvetrain is not an area I'd go cheap on.
Reply 0
Jan 10, 2005 | 11:06 AM
Quote:
Ill check out the comp pros did you hear of heartland rockers?
Reply 0
Jan 10, 2005 | 11:08 AM
Thanks for the info
Reply 0
Never heard of Heartland. I have, however, heard of Harland Sharp. Good rocker for the money. For the street, if it were me, I would still go Pro Mag's.
Reply 0
Jan 10, 2005 | 11:11 AM
Yeah thats what i was talking about lol, my goof up.Thanks for the help
Reply 0
Jan 10, 2005 | 11:26 AM
Id say it depends on budget and application.If your running a big a$$ cam then youll want the golds or the pro magnums.If its a cam thats under .500 lift go with the proforms or cranes energizer rockers.
I think the crane energizer series recommends not going over .550 lift,and they're basically the same as the proforms
Reply 0
Jan 10, 2005 | 11:34 AM
I think IM gonna go with the pro mags the price is pretty good $200, compared to the crane golds which are about $300.The Pro mag should be fine with the LT4 hot cam,i would think.
Reply 0
Jan 10, 2005 | 12:04 PM
DO NOT GET ALUM- NO MATTER WHAT
I have had 3 diff sets in various engines and I only got 24k out of ONE set the others all died shortly after 10k
Reply 0
Jan 10, 2005 | 12:13 PM
Yes the comp pro- magnums will work great w/ the LT4 Hotcam, thats what I run. Another benefit of them is the steel is much stiffer and less prone to flexing at high RPM's. At least that what COMP told me!
Reply 0
Jan 10, 2005 | 12:55 PM
Quote:
Yeah if you can find em for 200 grab em they usually run close too 300 bills if i remember
Reply 0
Jan 10, 2005 | 06:43 PM
Quote:
I might have to check again,Im pretty sure i seen them in for that price?I hope i didnt look up the wrong part #
Reply 0
Jan 10, 2005 | 06:52 PM
Your right the cost isnt $200,I looked up the Comp Magnum Rocker Arms.The pros are $265
Reply 0
Jan 10, 2005 | 09:23 PM
I have a set of brand new 1.6 SA Comp Pro Mags for sale, still in box for $250 SHIPPED!
Reply 0
Jan 11, 2005 | 07:02 AM
Quote:
Ill differently let you know as soon as i decide on which heads IM going with, Thats if you still have them.Thanks
Reply 0
Jan 11, 2005 | 09:14 AM
pro mags
you should get the comp cams pro magnum roller rockers. they are much stronger than aluminum roller rockers and are lighter too. they are a bit pricey but i would surely spend big bucks on something that plays a big role in the valvetrain, and you can pick up some easy horsepower from a easy bolt on job.
Reply 0
Jan 11, 2005 | 08:04 PM
I ran the narrow body Crane Gold roller rockers in my other van for about 4 months. I had a very small Ram Jet roller cam and changed my oil every 2500 miles because I'm nuts.
The trunion (?...fulcrum roller) bearings on all the rockers started to ooze out metal shavings. Not cool at all. I figured with my small cam and my driving habits (light foot) I'd be ok. NO.
Lucky for me Autozone took them back and I ordered a set of Comp Pro Magnums. I ended up selling these to a friend and he's had them for close to 2 years with no problems.
Reply 0
Jan 11, 2005 | 11:50 PM
comp mags or promags. you could get away with the mags but the promags are much better rocker arms. just save that $70 more...
Reply 0
Jan 12, 2005 | 12:07 AM
25THRSS: those rocker arms self-aligning or no?
Reply 0
Jan 12, 2005 | 12:19 AM
Quote:
They are, PM me if you are interested.
Reply 0
Subscribe
