Ac is working but not real cold????
Subscribe
Jun 19, 2001 | 10:20 AM
My AC system has been professionally retrofitted to R134a, It works with no leaks and has a full charge, but does not seem very cold to me. It there a specific part that could be changed to help the temp drop? And at idel at a stop light with air on, should my rpms be like 400, i thnk that is too low?? It drops that low but does run rough. Any help would be appreciated. Thanks, you guys are great.
1991 Firebird
3.1 Liter
No Mods(yet)
Reply 0
Jun 19, 2001 | 03:55 PM
Generally a 134a system will be a few degrees warmer than an R12 system, although that isn't always the case. Before you continue to speculate, put a probe thermometer in your heat vent. If it's in the low to mid 40s, then it is fine. If it's higher on a normal day (don't be surprised if it's 100 out and it doesn't blow as cold as when it's 75 out) then maybe you should have it checked out.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Reply 0
Subscribe
