How to do an oil change
Car: 1983 T/A
Engine: OUT (350 Block)
Transmission: 700-R4 sometimes
Axle/Gears: 3.23, moser 12 bolt >=3.73 someday
Does your car move at speeds greater than 40 mph or less than 50 mph? If so, tough guard filter is for you!
Such Bs. How does stop and go have anything to do with the advantage of a tough guard filter :-PZ
Such Bs. How does stop and go have anything to do with the advantage of a tough guard filter :-PZ I was wondering this, I've always changed my oil on a warm engine, but are you really getting more dirt out of the motor that way. On a cold motor thats been sitting a while everything is drained into the oil pan & filter, right? opinions?
Car: 82 Z-28
Engine: 383 TPI
Hot oil is thinner and will flow out faster. This helps flush any debris out with it. At least that's the theory as I understand it.
I like to get the eng throughly warmed-up. Park it and let it sit long enough for the exh to cool, then drain oil. The oil is still pretty warm, but I don't have to deal with a scorching exh pipe.
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
