Coolent in passenger footwell, Help!
Old Jan 12, 2005 | 09:14 AM
warlord's Avatar
Car: 1983 Trans Am t-top
Engine: 305 4bbl carb (vin code H)
Transmission: 4 speed automatic
Hi,
after i came back from the shops today, i noticed a puddle of green liquid in the passenger footwell, i assume it is coolent as my coolent is also green, also i noticed the coolent in the recovery tank had gone down my about 1-2 inches ( i noticed this before i started the car this morning). I took off the trim panel and saw a box thing, with a cable that moves when i move the heater leaver from cold to hot, so i assume this is the heater core? i could not see any tubes so does this mean the core is broken and needs to be replaced? i checked in the engine bay and every thing seems fine. are there any tubes inside the car that are hidden and could be split? also the liquid seems to be comeing from the bottom edge of what i believe to be the core and also from the leaver at the bottom that the control cable connects to, but i am not too sure on the achual source of the leak.
can any one advise me on this?
oh yes if it helps, my car has air conditioning and i usally leave the heater in the hot position and on the windscreen de-mist function (leaver far right) as it is usally misted up in the mornings.
Thank You.
Old Jan 12, 2005 | 09:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sounds like the heater core has gone bad. Major pain to replace. Do a search and you should find answers to questions you may have.
JamesC
Old Jan 12, 2005 | 10:20 AM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
Yep, heater core is the most likely suspect. Not complicated to replace, just difficult to get to.
https://www.thirdgen.org/newdesign/t...atercore.shtml
Old Jan 13, 2005 | 01:36 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
heater core $35.00 2 hrs. peice of cake install.....ummm; except those stubborn hoses under the hood from firewall to heater core stub-outs.
Old Jan 13, 2005 | 01:38 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Very straight forward replacement however difficult to access some screws. The only tools you should need include a 7mm nut driver, and pliers to pinch the clamps open. First repair I ever did in my car, and I was 16 years old.
Old Jan 15, 2005 | 11:33 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Sounds like you need a heater core, hoss. Very easy to do. Took me only 1/2 hour to do the whole job, and its cheap too.
MrPackstin
Oct 25, 2017 08:09 PM
Briandrex
Oct 5, 2015 06:20 AM
sjorgens
Oct 1, 2015 07:54 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
