good pistons that arent floating pin?
Old Jan 12, 2005 | 03:24 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
It seems that every piston Ive found in summit and jegs for the 383 had a floating wrist pin. Im lookin for one thats press in, and wud give me roughly 10-10.5:1 with 64cc heads. forged/cast/hyper^%&$, whatever, Ill take what I can get. Id definitely like to stay away from cast, but whatever.
Main ones I was lookin at were Wiseco and Sealed Power, they seem to have pretty good prices.
Old Jan 12, 2005 | 03:31 PM
ede's Avatar
ede
just about any that'll float will also be a press fit, whether the pin floats or presses is more a function of the rod, plus the pistion has to have the retention system for floating pins
Old Jan 12, 2005 | 04:02 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Don't look in the Summit catalog, look at the piston manufacturers catalogs. I know just about every piston company makes them. Never use one source for you information, don't be the next CBS news.
Old Jan 12, 2005 | 04:34 PM
spills's Avatar
Car: 89 RS
Ill have to use that one
Old Jan 12, 2005 | 06:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The pistons and pins are the same; it's a question of how the rod is prepped. You can put floating pistons and pins on rods that require pressing. You just don't have to use the Spirolox.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
LT1Formula
Aug 20, 2015 09:36 PM
Irocohio
Aug 12, 2015 08:03 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
