what's the symtoms of a bad head gasket
Old Jun 19, 2001 | 07:45 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I've got a 91'5.7L z-28, it slowly started to lope, like a cylinder is not firing. I've cheched the plugs and wires,rotor,cap and the injectors are working,I put in a new O2 sensor,and IAC, checked all the hoses. I'm at a stand still. I think its the head gasket.
Old Jun 19, 2001 | 07:49 PM
irocbsa's Avatar
White smoke out the tail pipe is a good indicator. You can also smell coolant in the exhaust. Plugs that foul quickly is also an indicator.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jun 19, 2001 | 09:21 PM
rezinn's Avatar
Plugs would not foul quickly with a broken head gasket, quite the opposite iirc. Look for coolant in your oil and very clean plugs.
Old Jun 19, 2001 | 09:32 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
What about blue smoke? What's that mean? Sorry, I always thought that was for head gaskets, lol.
Old Jun 19, 2001 | 09:45 PM
Enkil's Avatar
Blue smoke is oil, so most likely valve seals or piston rings.
Or a James Bond car.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 20, 2001 | 03:28 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Also, bubbles in the radiator at the filler neck with engine idling can indicate compression leaking pass the headgasket into the coolant.
White plugs getting 'steam cleaned' and/or white smoke from the tailpipe.
A compression test (or preferably a leak down test) will show it too.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
